Remove file/folder browsing from Civil 3D toolspace window
Did we need to see the files and folder in civil 3D toolspace window?
When I have project with 7000 files, only to navigate to Drefs it takes about 5 minutes.
I beliave it will be faster if there would be only Drefs. Even them we have more than 2000.
Why we can't open just using ribbon?
Darius
4 Comments
troma
Not sure what you mean.
Can you post a picture?
darius.simkunas
Only to go to the file takes 5-10 minutes.
Darius
troma
I've never seen that before.
I just jumped from 2013 to 2019, and I've never seen "projects" in toolspace.
(I assume you are in the Prospector?)
Is this a vault thing? I've never used vault. Do you?
darius.simkunas
Yes, it is Vault ingratiation to civil 3D. You can see this only when Vault server and etc is installed and configured.
In general vault integration is good, but we have performance issues with huge projects.
The main idea for Vault is manage big projects when you have lot of engineers working from different companies.
Answer Day
Rail Community
