read only option
read only option
PLEASE PLEASE PLEASE PLEASE Autodesk make Read-Only an option that you can set for a default option for Autocad LT. I don't like the lack of capabilities of Trueview so for our Engineers and Designers LT is the better option. I just want to be able to set the LT up to be able to open read only either by them opening a dwg from inside the program or by double clicking in windows explorer. PLEASE PLEASE PLEASE bring that ability into Autocad LT
7 Comments
BlackBox_
Not sure if there even is an AutoCAD LT 'ideas' forum, but to your request -
*IF* I understand you correctly, this is an IT issue, that can easily be implemented by making your drawing folders read-only through Active Directory / NTFS for certain Security Groups or Users.
As an example:
An 'Engineers' Security Group can be made read-only for the ..\Drawings\ project folder(s), whereas a 'Design CAD Users' and 'Survey CAD Users' Security Groups can simultaneously be granted modify access, etc. to the same folder.
HTH
doni49
Check to see if there is a command line option to start in READ-ONLY mode (something like "ACAD.EXE /R").  If there is, you could make a simple registry modification such that double-clicking a dwg file in Explorer will use that command line entry.
smurrin
BlackBox_,
Thanks for the reply. So if I have my admin do that permissions thing on the server, is it still just one set of drawings and folders.....ie when myself and my cad designers access the files/folder in question we can modify them but when the engineers access those same folders they only have the read-only option available to them? Smiley Happy
smurrin
doni49
Also thanks for your reply as well. So what you are saying is to check the program shortcut and see if I can set that up there to put the "/R" behind the exe file
BlackBox_
@smurrin -
That is correct; one data set, multiple account-based layers of access.
Separately, the /R switch is depreciated, and originally for the default pointing device. More on startup switches here:
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-8E54B6EC-5B52-4F62-B7FC-0D4E1EDF093A
Cheers
BlackBox_
DYAC!
Depreciated == Deprecated
smurrin
lol, i knew whatcha meant Smiley Very Happy
Answer Day
Rail Community
