"Renumber Tags" command should work line "Renumer/Rename Parcels"
Prohibit duplicate line and curve label tag numbers. Then make the "Renumber Tags" command function like the "Renumber/Rename Parcels" command. This means when you click on each tag in the order you want them re-numbered, if a number is already in use elsewhere, the tag elsewhere is automatically incremented to the next available number.
1 Comment
mikespelts
I meant for the title to say "should work like", not should work line.
Can't find where to edit my post.
