Purge unused Codes -> Code Set Style
I miss this button "Purge unused codes" in The code set style dialog.
We can create a new empty code set style and import new codes, but if we remove a subassembly, its codes remains in our code set style. To avoid creating a new empty code set style every time, I would like to use this button to remove unused codes:
The request of this command will be exactly like "Import codes" does: From assembly, from corridor, etc .... to pick the object and check its codes.
1 Comment
joantopo
  1. or even better: if we press "import codes" button, then should show a new option (yes/no) in the command line or dialog like "remove unused codes".
  2. This option will be showed after selecting Corridor/Region/polyglon..
Answer Day
Rail Community
