Purge codes in the Code Set Style.
In the Code Set Style there is the button [Import codes..].
I would like to have another button called [Purge codes..], so, if the Code Set Style contains some code which is not being used in the corridor /or Assembly (depending of the selected object), then that code is removed in the Code Set Style.
Yes, we can create a new Code Set Style (empty), but then I have to set again all styles for each code... (that´s a lot of work).
Answer Day
Rail Community
