propose alignment geometry parameters
It's a pain to connect alignment entities with desired elements, you're prompted to insert connecting (spiral / curve) length / parameter values etc, which too often results in "no solution" available, the elements won't fit. The soft should assist the engineer, you can't calculate it all by heart. The possible values should be prompted or drawn so you'd have the possibility to edit the geometry afterwards.
Answer Day
Rail Community
