Pressure Pipe Network Profile Line Attachement
Can you please add an option to attach the pressure pipe network profile line to the pipe center line or the pipe invert? When civil engineers submit plans we typically show the invert or centerline elevation, not the top of the pipe. When I want to label the pipe invert or centerline I need to create a custom label expression for each pipe size I'm using. The top of pipe profile attachment is also a nightmare to adjust when I have a reducer and valves in the profile.
Also, please add an option to show the pipe connections touching in the profile view where we have joints. Another work around to the profile attachment issue is manually adding in a profile, but I can't snap the profile geometry point to the invert or centerline because it's not shown due to the pipe joints hiding the pipe's point of connection.
Making manual adjustments is adding hours of extra work to a project and if we are editing the pipes we may forget that we made a manual change to the label and submit a profile with incorrect elevation data.
Idee einsenden
Rail Community
