Pressure network fitting label leaders point to fitting
Fitting label anchors right now create a box with around the extents of the fitting, and that is what the leader targets (see attached image). The box changes size based on orientation, so it works okay if the part is oriented at a perfect 90 degrees to the view, but it's still very inconvenient.
2 Comments
BrianHailey
To add to this, I would like to be able to manually adjust the leader location for any label in the dragged state.
scott.rosslow
Also looks weird if using Northing and Easting since the leader doesn't point to the Northing or Easting.
Answer Day
Rail Community
