Predefined Styles and Label Styles to Code Set Style Codes
Hi, it would be very helpful if it`s possible to set default Styles and Label Styles to each Code in a Code Set Style. So if I import a Code Set Style into my drawing it will not be necessary to switch into the properties of the Code Set Style and to choose a Style or Label Style manually.  So the settings for the Styles of each Code are saved within the Code Set Style, even it`s transported between .dwg`s.
1 Comment
f_furger
I support this idea! It would massively speed up certain workflows.
Answer Day
Rail Community
