Possibility to set curb returns' targets in the Intersection Wizard in Civil 3D
When the assemblies used for Intersection creation have more than one target e.g. Lane (LaneSuperelevationAOR) and shoulder (ShoulderExtendSubbase), and their names in the Corridor properties>Parameters>Target are: "Width Target" (for Lane), "Offset Target" (for shoulder), then in the intersection wizard, the target objects are assigned alphabetically to the first on the list, which causes wrong intersection geometry - width target is assigned to the shoulder instead lane. Once an intersection is created, targets have to be manually adjusted.
Able to set/choose which subassembly uses targets in the intersection wizard, may help to assign targets correctly upfront(no manual adjustments) and use more complex assemblies with more than one offset target.
Answer Day
Rail Community
