Pond Creation Tool
Pond Creation Tool
How about a pond creation tool.
Create a pond name, set parameters such as inside slope, external slope, slope height/level, base depth/level, freeboard depth, width between top of slopes, tie-in surface.
Then have an option to draw the pond manually using base or top. An option to draw the pond by measurements using base or top. There could even be an option for using objects such as featurelines or polylines.
Surface creation of the pond and also a surface created for the water at the freeboard depth level, this could be used for volume calculations.
This would all need to be associative so that if the pond size is altered then everything else would update.
Answer Day
Rail Community
