I tried to insert points using "create points - alignments - from file" using a text file that was hand/macro generated. The file had a space after the elevation, right before the comma that precedes the description. I used option 5 (station, offset, elevation, description). All the data came in except the elevations of the few points that had a space after the elevation. Why does this happened in a comma delimited file? Is there a fix for this?
I agree that this is a bug since the file is comma delimited. I along with others commented have this problem in the point description. If you search and replace the space the point descriptions become one "word."
This problem has existed for a while and never has been fixed. It is about time that a comma delimited file does not glitch if there is a space in it.
