PipeNetwork Labels - default location in label style instead of inside command
Currently you can only set the default pipe network profile label placement inside each different commands (ie: addnetworkpartproflabel)
This is annoying because I have different labels that I want placed at different default location base on the label style.
The default location should be a setting inside the label style. Not all your pipe labels will be set at the same spot and forcing the default inside the commands instead of the styles makes it annoying to change that.
If you're like me: My top structure text style will always be anchored at the top of structure while my bottom structure text style will be anchored to the bottom. So why force me to only have 1 default option ?
Plot height value and other options might also be different base on existing structure vs proposed. Give us more default leeway be making the default inside the style instead of the commands please 🙂
ps: you should also split the plan vs profile labe types instead of having them all in a big melting pot.
Answer Day
Rail Community
