Pipe Run Profile Settings
After I create a pipe run, I create a pipe run profile.  Below are the button and dialog.  The default setting in 2021 was Cut Length, in 2022 it is Offset at Fitting.  There seems not to be a setting to change this default, at least not that I can find.  If indeed it does not exist, my wish is to have the option to change the default.
I use pressure pipes to model existing underground utilities that should follow the ground at a depth and I must change this setting for each pipe run as I create them.
2 Comments
Ayrton.gomez
Community Visitor
great idea!
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Answer Day
Rail Community
