PIPE NETWORK PROFILE
Now Civil 3d pipe network profile is creating from an option 'Alignment from Network' , which means network structures and pipes and alignment act as two different elements. Hence what are the issues we get is,
1. Structure station values and structure center to center length act as two independent values, no relation at all. We get two different values in station, as the rounding options will increase the digits in pipe length and alignment is continuously reading the length to that structure. So for a cumulative of, say three pipe lengths will adding together must get the station but it wont.
2. Data short cut manager wont work for revision files. Because while updating with revised drawing through data short cut manager will disappear all the labels in layout and profile views earlier set will turn empty. Reason seems like we are creating profile from alignment and inside a pipe network contains several structures and pipes then lines as a whole part not segmented.
Answer Day
Rail Community
