Pipe and Pressure Pipe Networks: Maintain Styles assigned when Data Referenced
Most design utility networks tie into an existing network, or different pipes may required different styles for the same size of pipe in the same network (most often, some existing and some proposed).  When data referencing that network to another drawing, if you've already changed some parts to a style other than your defaults, it would be extremely helpful that those stay whatever the assigned style is, so you don't have to change it in multiple subsequent drawings.
An alternative would be to allow different networks to connect to each other with some kind of "intersection"-type function, which a similar idea appears to have been posted.
Answer Day
Rail Community
