Pick Up and move-change objects style attributes directly on the model.
It is incredible how annoying can be to work with styles on each object or new object you want to customize. Open a property window, which has another set of attribute settings and... open one nested more to find a new set of attribute options. Then you want to apply... apply... and APPLY AGAIN! to finally get out of that, but just to start another object on your drawing and, time and time again for each new object you add to your project. Time wasting, and ridiculously tedious. Why isn't there a way to just grab an object (inside the mother object i.e. profile view, section view etc.), move it, or right-click that object to get a fast attribute menu (for color, size etc.), then an option on that window "apply as object style", and then all off nested objects corresponding with it change in the same way at the same time. So fast and easy and not that apply... apply... apply.. and apply thing.
Answer Day
Rail Community
