Organizer for surfaces
@Chaznsc - your subject line has edited.
I would love a surface organizer. If nothing else, to separate my COMPARE, EXISITNG, and PROPOSED surfaces.
2 Comments
camden.n.dean
Perhaps you already know about this, but there is at least foldering in place for surfaces already. You will have to manually sort each surface into the right folder (as far as i know), but you can have a folder for COMPARE, EXISTING, and PROPOSED.
To do so, just right click on "Surfaces" on the prospector tab of your toolspace. Then select "Create Folder." Finally, drag a drop existing surfaces into folders. You can also make these folders in your data shortcuts.
-Camden
TimYarris
Thank you for posting your idea, @Chaznsc. Would you please let me know whether @camden.n.dean 's suggestion to use Prospector folders suits your needs?
Answer Day
Rail Community
