Offset alignment SET.
Basically is a template.
This idea is extracted from Clip Toolsa software which have a similar tool.
Civil 3D API needs a new object (style) called "Offset Alignments Set".
It would be placed in the ToolSpace (Settings Tab) within the Alignment category.
And the command:
CreateOffsetAlignmentsSet , to define a new Offset Alignment Set.
Another command:
"CreateOffsetAlignment_FromOffsetAlignmentsSet".
This new command, "CreateOffsetAlignment_FromOffsetAlignmentsSet",  won´t replace the current "CreateOffsetAlignment" command.
The aim is a quick way to create offset alignments with different offsets in plan view. (in this case, we don´t need also create their design profiles, just in plan view).
CreateOffsetAlignmentsSet command:
If we call this command, it will appear a dialog box to define until 5 offset alignments in the left side and until 5 offset alignments in the right side.
Notice that you can´t select the parent alignment here, it is just a definition set which you will save it in your drawing template.
**See the attached picture.
About selecting alignment labels set for each Offset alignment I don´t think it is necessary.
"CreateOffsetAlignment_FromOffsetAlignmentsSet", command.
If you call this command, then you must select the parent alignment and a "Offset Alignments Set", to create the corresponding offset alignments.
Answer Day
Rail Community
