Need pipe crossing data labels in plan view
It would be nice to be able to tap into our pipe modeling data to produce labels for crossings. I've seen a few other postings that had a fair amount of interests but none of them covered it in this way.
It would be very helpful if the Interference Check feature worked between Pipe Networks and Pressure Networks. It would also be nice if a label could be produced with the data at a crossing especially once the conflict has been resolved it needs to be labeled. We need to show/label that it works on the permit plans (example image attached). The label is necessary in plan view, with Surface Elevation, with Top/Bottom of both pipes, with clearance distance, etc.
BTW, aside from this, it would make a whole lot of sense to rename Pipe Networks to Gravity Networks since we have Pressure Networks now.
Answer Day
Rail Community
