Multiple edit in bands tab
Dear Autodesk and Civil community 🙂
It would be really nice if users could edit multiple bands at once. It should be allowed in all dialogs which have multiple rows. Please, this can speed up work very much and it seems like a very easy programming!
Proposed functionality? (LIKE IN CODE SET STYLES)
Select one, hold shift and select other - all rows between will be edited as well.
How it works now? (BADLY)
Like this... But it could not be like that 🙂
8 Comments
st35281
This workflow would be also nice when working with surfaces. If you want to delete some changes you made to the surface it is possible only one by one. Sometimes it is easier to delete for example the merged surfaces and start all over. 🙂
gros33
Yes please!
jirasek
Yes, Yes, That would be great!
jakubkares
Another dialog where it is not possible to multiple edit 😞
jakubkares
The dialog where you can multiple edit - OK !! 🙂this is great :-) !!this is great 🙂 !!
jakubkares
Editing surface style works great - OK!!  🙂
jakubkares
Selecting multiple regions in corridor parameters is not possible - BAD BAD 😞
this is not OK :(this is not OK 😞
jakubkares
Another multi edit case - DREF deleting
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/delete-multiple-shortcuts-option/idi-p/7622259
see this thread 🙂
Answer Day
Rail Community
