Move the subassembly on top of the others in the Section View in Civil 3D
Move the subassembly inserted as the last one to the assembly on top of the others in the Section View in Civil 3D in order to see particular elements correctly:
7 Comments
SoaresASBCAD
Nice
f_furger
I support this idea. A possibility would be to specify an order in the assembly properties (tab construction):
SoaresASBCAD
yes, it would be good
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
joantopo
Hi @f_furger
I partially share your opinion but not the place to add that improvement. The sort of the subassemblies decide the priority of which subassembly must be calculated before.
To add this new feature I would do it in the "section" tab in the Section View Group Properties. There is listed sections (surface sections and corridor sections) and there we change the styles. So we could have those buttons (up/down) to up/down the section in the list.
I generally do "QSELECT" by source name and then "sortOrder" but it is not dynamic if I add/remove new sources later.
f_furger
Hello @joantopo
I know what you mean. The refernce order between input and output parameters would be affected.
The idea with the new tab in the Section View Groups would definitely be a better solution!
eric.sanderZXX9E
Very useful idea and improvement! I just talked with a custimer above this behaviour and have a support case at autodesk.
