More options on properties dialog
It would be helpful if there was an option to change what appeared on the standard properties dialog.
For example, for our structure parts (manholes) I have added an option to change the cover grade (ranging from A15 to F900, with it defaulting at D400). It works fine just now, but you need to go into the structure properties to change the cover grade. It would be save alot of time if I could select the manhole and just change the cover grade in the properties dialog. The same way you can change a pipe size, or for a label, the surface it points to.
Whilst I accept that not a lot of people will use this function, if the properties dialog was more editable people could decide what to include.
Answer Day
Rail Community
