More operations between surfaces.
Terra Power Tools has a lot of tools for this:
https://civilplus.net/product/terra-power-tools-for-autocad-civil-3d/#terra-power-tools-application
Surface object in Civil 3D is great but it needs a lot of new tools when we want to treat between 2 surfaces:
-Merge surfaces according to several criterias:
* Create automatically "vertical walls".
* Take the top of each one to merge them.
*Take the bottom of each one to merge them.
other criterias.
In general, Istram Ispol does these operations according to several section surface data (in a file) instead of using TIN surfaces directly and they return a new file. (surface section data).
1 Comment
autoMick
Yes please... something that allows us to merge multiple (even 2 for a start) surfaces and use criteria such as elevation, instead of paste order to determine which surface takes precedence.
Mick
Answer Day
Rail Community
