More functions and properties for the projected objects in the Profile Views.
My wishes:
-Support for projected objects (in profile views or section views) in API.
About the "Projection" tab:
I think that the "projection" tab should be a palette instead of a form.
In that table, it should appear more information like: station of the point and perhaps the offset.
-Sort the table by station. (I think that now the objects are ordered by the moment of the insertion).
New command:
-Select in Plan View an object (AutoCAD point, COGO point or block) and check if that object is projected in some profile view or section view.
Perhaps, if we select the object and press button right of the mouse, a new command in the contextual menu (check if it is a projected object).
How the object can below (being projected) in more than one section view or profile view,then the command should show a table with all them (profile views and section views) and next to them a button to do "zoom" to the selected profile view or section view.
-a new property for the PVI´s of the layout profiles to anchor some PVI to a projected object in the profile view, so if the elevation of the projected object changes, then the elevation of the PVI also changes and it is dynamic.
Answer Day
Rail Community
