Missing variable in new Offset Geometry (SAC)
Hi guys,
It is not clear why offset distance in SAC is exact value and cannot be used input or output parameter. Anyway it has no big sense.
Martin
4 Comments
doni49
I'm not sure what "offset distance" you're talking about.  Points use XY values that are relative to another point in the SA.  You can even specify to WHICH point it's relative.  Each XY distance can use an input parameter to control its value.
doni49
I stand corrected.  I now have 2016 installed and see that SAC 2016 has something called "Offset Geometry".  I can confirm that attempting to put an Input Parameter fro the Offset Distance causes SAC to IMMEDIATELY remove it from the properties.
doni49
Until such time as they fix this, you can use the following to get what you need (it actually works without needing the offset geometry).
In this example, P3 is created by turning 90 degrees from the line P1/P2 (with P1 as the angle point) and going a distance specified by the offset parameter.
From there it created P4 at the same slope as L1.
elvinlee
I feel this is such a wasted tool if you can't put in an Input Parameter and you must hard-code the value in. I know of the angle and distance method, but I think this offset geometry could help clean up the flow chart.
Answer Day
Rail Community
