Make fixing overlapping vertices in polylines easier to fix
There needs to be a better way to merge or get rid of overlapping vertices within the same polyline.
I've tried overkill, mapclean and weed, but none of these seems to remove vertices that occupy the same point in space.
The only way I've found so far to remove them is pedit>edit vertex>move and then remove it manually.
There has to be a better way to accomplish this?
