Make editing label text respect the TEXTALLCAPS System Variable
The TEXTALLCAPS System Variable makes all new text created by text or mtext commands uppercase. No need for shift or Caps Lock.
Civil 3D labels don't respect this system variable, which may be ok as they can be controlled by style when initially created. However, if a user selects a label and then chooses to "Edit Label Text" the Text Component Editor doesn't recognize or respect the system variable.
This becomes the only place I need to remember to use Caps Lock in my typical use. So I usually forget and have to redo my typing.
My thought is that the Text Component Editor, and other text editors that I haven't mentioned, should respect the TEXTALLCAPS system variable.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Answer Day
Rail Community
