Looking forward to more and more complete Chinese versions of the official Civil 3D Dynamo
For users in non English speaking countries who are not particularly proficient in English, learning and using a semi English and semi Chinese operating interface is difficult. We look forward to the official provision of a more complete software with Chinese translations.
2 Comments
TimYarris
Thank you for your idea. Currently it is not possible to localize certain items such as expressions of code, Node names, Library names, Class names, Boolean operators, Types of variables, etc. This is because localizing these elements would be a breaking change to existing graphs.
We are working on translating the "Dynamo for Civil 3D" section of the Dynamo Primer to all existing Primer languages, including Simplified Chinese, however.
Would you please let us know if there are specific areas of the User Interface that should not be left in English?
多情的娃娃
Firstly, thank you for the official response to the 0 vote (as of now).
As you said, if we cannot further localize the software interface, I have no other good ideas to tell you. This is like the Autodesk Subassembly Composer for Civil 3D, which uses a non-standard compiler language.
If it doesn't change, keep going like this. This will severely limit the user base for localizing Civil3D, and the threshold for learning and using Civil3D will become higher, which is not conducive to the promotion and use of the software in non English speaking regions.
Answer Day
Rail Community
