Limit Offset Profiles in Intersection Lane Slope Parameters to profiles belonging to alignment specified in Intersection Offset Parameters
When creating an intersection through the wizard, there is an opportunity to specify use an existing alignment in the offset parameters dialog box. Then,there is an opportunity to specify use an existing profile in the lane slope parameters dialog box. If an existing alignment has already been specified in the offset parameters dialog box, then the existing profiles available to choose from in the lane slope parameters dialog box should be limited to the profiles belonging to the existing alignment previously specified.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Answer Day
Rail Community
