Iowa Regional Coordinate System
Are there any current or future plans to add the "Iowa Regional Coordinate System" to your mapcs library?
12 Comments
A few questions:
1. Has the system been approved or is it still proposed?
2. Has the system been registered with EPSG?
Right now this isn't on our list of things to do, but these local low distortion projection systems are happening all over the world. They can be added to Civil 3D by making a custom coordinate system right now. For the future, we'd prefer to derive our library from EPSG directly.
Peter Funk
Autodesk, Inc.
augdog74
1.) The Iowa DOT designed it and it has been publicized since 2014.   http://www.iowadot.gov/rtn/IaRCS.aspx
2.) I can't tell you the answer to this question, but I can probably contact someone from the IDOT and ask.
I have created some user defined coordinates for now but wanted to alert you on this.
augdog74
Here is the info to your 2nd question:
http://www.epsg-registry.org/
14 zones
EPSG codes: 7057 to 7070
anw52
I also would like to know if/when this system will be added.
thoodjer
Community Visitor
Would also like to see theses systems added
Matt.Haney
This keeps coming up over the past few years. IMO most Civil firms in the state of IA would prefer to use and have IaRCS available in OOTB form in C3D to use rather than IA State Plane . Since it is official with EPSG will Autodesk please add this into C3D.
augdog74
I'm not sure why it isn't being incorporated into the new versions?
KWinslowOA
@peterfunkautodesk
I have linked below to a screenshot of the EPSG site of the with "IOWA REGIONAL Zone 1"  Coordinate system. There are 14 in total on the EPSG site also numbered below.
Iowa DOT has a zip file with all the PRJ files in it at this site. https://iowadot.gov/iarcs/
If there is any other info you might be needing just let me know. I can try to dig it up for you.
EPSG::7043
EPSG::7044
EPSG::7045
EPSG::7046
EPSG::7047
EPSG::7048
EPSG::7049
EPSG::7050
EPSG::7051
EPSG::7052
EPSG::7053
EPSG::7054
EPSG::7055
EPSG::7056
Iowa Survey and Civil firms
jmoellering
Please send out some kind of alert when the coordinate system patch is available.
KWinslowOA
@peterfunkautodesk
Any update on this? I think I provided all the information you requested above.
Matt.Haney
2019 Civil 3D now has the IaRCS zones all included in the OOTB install of available coordinate systems.
KWinslowOA
@Matt.Haney thanks for the 2019 update that's a huge help. I'd mark you as the solution if I could. #GoHawks
Answer Day
Rail Community
