Insert corridor regions as csv or txt
When we create a lengthy corridor most of the times we might come across number of structure locations where we have to change the assembly. However these locations of the structures are predetermined and what we have to do is to just manually insert these regions to corridor. But if we can import these sections through a csv or txt file we can save some time.
What I suggest is to 'insert from file' option at the 'split corridor' in civil 3d to feed these predetermined locations to corridor.. Then civil 3d will automatically get the alignment, profile and assembly details while Split chainages can be feed through the imported file.
The vise versa which is export corridor regions as csv may also be use full.
Answer Day
Rail Community
