Incorporate network inlet structures into catchment/waterdrop analysis
Not every inlet structure is designed in a surface depression. As a result, Civil 3D ignores the network structure during a catchment/waterdrop analysis because it is not detecting a surface low point. A current workaround is to add the structure rim and bottom as breaklines to a copy of the surface being analyzed, but I'd like to see an option to automate/simplify this. I would think the most straightforward way to do this is to add in an "Add network structure to surface definition" option somewhere.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Answer Day
Rail Community
