Improving offset assembly
I love this demonstration using an offset assembly.
http://civilimmersion.typepad.com/civil_immersion/2017/11/finish-strong-friday-the-disappearing-curb...
The issue is the offset assembly just can use an alignment as a BaseLine. Corridor feature line is not allowed.
Also, I would like to select the corridor FL originated from the same corridor.
Due to the profile is optional to define the BaseLine of  the offset assembly, I would like an option to ignore the elevations of the FL in case we select the FL as a BaseLine of the offset assembly.
1 Comment
awkeller88
I'm thinking rather than adding in an offset it would be nice if you could just toggle on/off the option for the sub-assembly to build perpendicular to what it's parent is targeting. Same result just less offsets/targets.
~Andy
Answer Day
Rail Community
