Improve structure properties in a pipe network
Hi.
Structure part has a "Angle" of rotation property, to rotate the structure.
In case of "Inlet-Oulet" structure the user must rotate (using Object snap "Extension") this type of structure to match with the direction (bearing) of the previous pipe.
Could you add in the "Angle" rotation a new option to choose "match with direction(beraring) of the previous pipe" so the user does not have to do this every time? If I move the structure it will rotate automatically.
I understand that in other types of structures such as manholes or junctions a structure can be connected with several pipes, so this criteria would not work if the structure has more than one pipe connected. (or if Structure subtype is not "Inlet-Outlet").
Thanks in advance.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Answer Day
Rail Community
