Improve cropped surface command
Some input parameters to create a cropped surface should be optional such as the boundary.
If I have a corridor surface and I disable most of the corridor regions, why do I have to select a boundary (from object or polygon) if actually I just want that corridor surface entirely in a new detached surface?
And why we cannot create the new surface in the current drawing directly instead of creating the surface in another drawing and then copy/paste?
Why don't you create a new command called "create detached surface" in the context menu of a surface?
For example, grading tool bar has the command : create a detached surface. Why don't you name it equal?
1 Comment
alexey.kurenkov
Good idea. Let the corridor work as Grading Creation.
Answer Day
Rail Community
