Import subassembly: get ALL codes from the subassembly
Depending on you saved your pkt file the last time and you imported it later, you will get codes or other codes if there are Decisions in your custom subassembly.
Have a look to this post:
http://forums.autodesk.com/t5/autocad-civil-3d-general/loool-civil-3d-doesn-t-take-all-codes-from-th...
So, In the subassembly properties. (Codes tab). I would want that Civil 3D showed all the codes of the subassembly, not only the code links or code points from Decisions= True.  (also from Decisions= False).
Answer Day
Rail Community
