Import LandXML - better handling of identic surfaces
Example:
- I have a DTM (a surface) which is named "test".
- I import a LandXML which contains another surface called "test"
What will happen? It will import the data, will modify everything and gives the a small message "surface test was modified". Maybe I have destroyed all my data
Idea: Add a data-handling at the state of the art
Example: Import of blocks; saving of files..
That means:The software informs me before(!!) importing:
You want to import the surface "test" which already exists in your drawing.
Do you want to skip / merge / replace the data?
Answer Day
Rail Community
