Ignore only edge tris with long lengths
In the build options for a surface, you can set max tri length, most people know about it...
I wish it only affected "edge" triangles though, as interior ones are common for things like lakes where I do want the triangles.
thanks
1 Comment
James,
Look at the option "Use maximum angle between adjuacent TIN lines" this will remove only edge triangles that have a oblique angle opposite the surface edge (i.e. the long side of the triangles). I'd start with 120 as the angle.
Cheers,
Answer Day
Rail Community
