Hydrants & Caps/Plugs
Please add caps/plugs the all of the parts lists (pressure network & pipe network). Also, add hydrants the the DIP parts list so I don't have to change to the PVC parts list if I am actually working with ductile on a project. Lastly, when you display a hydrant on a profile, could you give us an option to set the base of the hydrant (where it connects to the riser) at a user defined elevation in relationship to a user-selected profile (surface or design). Ideally, the user defined elevation would be formatted in a way where the user specifies an elevation difference (i.e. +0.25-feet) above the surface elevation.
Answer Day
Rail Community
