Hold Update Grading While inserting PIs
While editing a graded featureline, if you are inserting a PI, the grading will update at both the XY and then the following Z.
The insert PI command consists of two questions on the command line/interface.  Place the PI then enter the elevation.  Both trigger a grading update.
Ideally, the grading update should wait until the end of the entire edit, which might consist of multiple PIs, (the command stays active allowing for multiple PIs)  But at the bare minimum, the two step process should wait for both actions to be completed before triggering and update.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Rail Community
