Highlight first the selected row in the Parameters tab (corridor form).
When you open the Corridor Properties form, in the "Parameters" tab, you can pick on a button [...] (targets, frequency,...) for a particular corridor Region.
The issue is the new selected row is highlighted after you close the dialog box (targets, frequency,....) etc.---- I hate this behaviour.
So, the properly order in the programmation should be:
1)If The user pick on a button, then:
2) Select and hightlight that row.
3) open the dialog box.
This is very important because dialog box are modeless and you would be able to see the name of the Region, of the assembly,etc..if that row was selected first.
Answer Day
Rail Community
