Gravity/Pressure Pipe Display - Top & Bottom of Pipe Toggle On/Off
We have to meet some strict CAD standards that often require us to only display top or bottom of pipe in profile view. Currently the workaround is to use a "no plot" pipe style and then manually draw this bottom of pipe. For obvious reason, this is not ideal due to any changes requiring edits to the manually drawn linework.
Having a display style option to turn off top/bottom pipe would be ideal.
I am sure this gets complicated since there is a toggle for inside/outside of pipe under the "display" tab. So maybe this setting is better suited to be under the "profile" tab of the display style instead.
1 Comment
Michel_Denuit
It should be very interesting for us to give the information of the bottom generator of the pipe (that's  the factor for the earthworks altitudes).
Answer Day
Rail Community
