Grading - Conflict Resolution Transition Zone
We need a resolution method that allows us to specify a distance from the interior corner to indicate how far away from the corner to hold our projection slope. Elevation points would be placed at the red X's below to lock that down.
We need this to keep the daylight line (or more likely gutter pan offset) from changing. Currently the whole things changes.. We need to transition our gutter pans only through the corner, say 2' out from the corner each way.
The edge of pan needs to stay at its constant elevation differential relative to the gutter flow line until it gets 2 feet from the corner.
Answer Day
Rail Community
