Flexible DMS/DecDeg Display in CS Library
In the Coordinate System Library of Civil 3D 2010, Latitudes and Longitudes were displayed in Degrees-Minutes-Seconds:
In the Coordinate System Library of Civil 3D 2016, Latitudes and Longitudes are displayed ONLY in Decimal Degrees:
It would be nice if you could set the Coordinate System Library to display either Decimal-Degrees or Degrees-Minutes-Seconds by changing the Ambient Settings:
Dave
2 Comments
sboon
I'm pretty sure that the Library you're showing for 2016 is part of the Map software, not programmed or controlled by Civil3d.  Another example of two systems which need to be integrated properly.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Pointdump
Hi Steve,
That would explain the disconnect.
Dave
Answer Day
Rail Community
