Fixed Size For Point / Point Label Styles
I find that cogo points are too close together to view or plot at any annotative scale.  I like to keep them just small enough that I can read the labels without them running into eachother. The problem is that if I change the annotation scale for any reason the points don't show up like I would like them too.  I would be much happier with point/point label styles that were not annotative.
2 Comments
doni49
Have a look at this & as a secondary option this.
stacy.dunn
We have found that this is not necessary if you have a quick way to change the point label styles.  We created a tool that allows you to resize the text height of a style in a couple clicks.  It allows you to change the point label heights as quickly as you could with the Display Properties command did in LDD.
Answer Day
Rail Community
