If I use select similar on a dynamic block in autocad, autocad selects all instances of that block.
If I do the same thing in CIVIL 3D it only selects the instances of the block that happen to have the same parameter values.
For a lot of our dynamic blocks, this makes using select similar next to impossible.
It would be usefull to at least have a system variable or something to switch between selecting all blocks or selecting only the blocks with the same parameter values.
I know quick select is a thing, but it's extremely tedious to use most of the time.
