Fix Missing Annotation Panel in Block Editor
https://forums.autodesk.com/t5/civil-3d-forum/annotatation-template-problem-extracting-areas/td-p/59...
https://forums.autodesk.com/t5/autocad-map-3d-forum/missing-annotation-panel-under-block-editor-tab/...
Autodesk needs to either fix the Help for To Define an Annotation Template or put the Annotation panel back in the Block Editor. This has been known for 8 years and Autodesk still hasn't fixed it. This is still an issue with C3D 2022.
1 Comment
Pointdump
Still no in 2024:
Answer Day
Rail Community
