Feature Lines
Feature Lines
when you raise a feature line to a surface (elevations from surface), you're given the option to select multiple feature lines to follow the initial line (up or down to the surface) in the same command. It'd be nice to have this option when you're raising or lowering multiple feature lines by the same amount (incremental raising). Which is useful when you're still trying to match an existing elevation, like existing pavement (in lieu of raising or lowering an entire surface).
Answer Day
Rail Community
