Feature Line Input
Feature Line Input
At my work, 90% of the time we are putting in feature lines using elevations.  when you first use the feature line command the default is by grade.  if you dont change the default to elevation, we end up with a mess because we were putting the elevations as grades.  we need to be able to set the default to elevations in our template.  i find it ironic that we are able to set it after the first use in the autocad program and it will hold the entire time the autocad session is open.  close it and it reverts back to the grade default.
Answer Day
Rail Community
